Simplistic Speed, 100% done, pics posted! **Lightweight**
Re: Simplistic Speed, Let there be lights! **Lightweight Build**
hey Pm'ed you
Troy
Re: Simplistic Speed, Chainring Photos! **Lightweight Build**
Thanks, Luke, here it is!!
Well, the initial design didn't work out, see previous posts. After drawing in plan A I drilled the holes for the saw to start the cuts.
You can see at the bottom of this photo the attempt at plan A. Plan B needed to remove that cut and most of the previous drill holes.
Continuing to cut plan B
Here's all the major cuts done, looking like it was cut by a third-grader :lol:
Here I'm using a carbide bit to grind the cuts and make them even. The bit throws off shavings that are metal splinters, I found this out after I started with exposed hands and arms *sigh*
Done before it's vinegar bath, just needs a little finishing then on the bike :)
Re: Simplistic Speed, Cut Chainring Photos! *Lightweight Build*
The lines on that chain ring look amazing!! great job!
way cool on the chain ring!!!!
Troy
Amazing work here!!
Beautiful design and flawless execution of a SICK brainstorming!!
WELL DONE!! :mrgreen:
LOVE the way the chainring turned out.
awesome!
I've been so focused on my build, I just haven't taken time to really see how everyone else is coming along? This build is truly outstanding and that chainring is mind blowing! All I can say...is Wow!
Thank you! It does mean a lot to me that others appreciate my efforts and designs.
Thank you, fordsnake. I have the highest gratitude for your experienced opinion.
I've added some brass screws to break up the chrome.
Re: Simplistic Speed, Headbadge Done! Soon pics! **Lightweight**
Well, this has been in the background bet worked on for awhile. I knew it was going to be the last piece I put on and I finished painting it today.
My GF is an amazing sculpture so she made a headbadge for me!
She then made a rubber mold of it so I could make them from 2-part epoxy
Here's the final being drying against the frame so it doesn't shrink past the diameter
And finally painted and patina added
She's now 100% done, on to photos!!
