Too tired to post the pics of the Harley fork, but this is what I am thinking of using instead of the Girvin.
![20200617_201108.jpg 20200617_201108.jpg](https://cdn.imagearchive.com/ratrodbikes/data/attach/126/126041-20200617-201108.jpg)
weld on new dropouts for a mo betta mo room stance. or flip dem forks around...
GC.
You could also fab up some new arms for that Harley fork that would accent the style of the bike. About 30 feet of tubing and a pipe bender. I would make them up on cardboard and let a shop do the drilling and bending and crushing for me. In my case it wouldn't work and I'd have to redesign it two or three times. That why I would need 30 feet of tubing!Too tired to post the pics of the Harley fork, but this is what I am thinking of using instead of the Girvin.
So....I see what you mean how the upper and lower Girvin brackets fishmouth back towards the head tube instead of the lower sloping forward like usual
Not enough meat on the head tube to shorten it significantly (even if you wanted to perform surgery)
Theoretical option would be engineering something to lower the pivot/mount on the fork side of the bottom plate to try to get the upper and lower plates close to parallel
That's a head scratcher![]()
Bummer about the fork but at least you didn't have an ugly crash (especially if the chicks were watching). I've grown so used to seeing the Girvin on there that I'll probably have to relearn several major life skills while I adapt to seeing the new fork.
That is a cool fork thoughI didn't have much time before sundown last night, but here is a fork that I tried that was a quick NO. I have this TSP fork (which is actually called a Demon fork), that I tried because it has a long steertube and was easily wide enough for the wheels. It just isn't right for this build at all.
View attachment 125949View attachment 125950
I can see it now . Kingfish breakenout his Yoga moves .
I love this Indian/Harley fork that I picked up last year and it was an obvious fork to try next.
It is not without issues with this frame though. You can see in this pic that the headtube is so tall that it uses all of the steertube to install this fork for a mockup (and there aren't even any bearings in for this test.
This doesn't even leave any threads for the top nut
Or the upper springer yoke.
So for mockup purposes I slapped on some of them fancy threadless stem spacers thingies and squished them down with a quill stem to hold the upper fork yoke on.
View attachment 125956View attachment 125958
View attachment 125959View attachment 125960
Shameless..........
