I wanted v brakes on my latest project, had a donor with nice hardware. Follow along as I figure this out.
Center to center spacing on mounting bolt for the donor is 80mm, the mounts sit with the center of the mounting bolt even with the inner edge of the fork tube. 80 mm to inner side of tube.
Project bike is 82mm to inner side of tube. Pretty close. Even if they are not this close, not a problem, you'll just have to grind to fit, or plan your fixture better.
I measured donor from center of mouting bolt to top and bottom of rim edge. Top of rim 15mm, bottom of rim 35mm, this will vary on the bike you're mounting on so I decided to use top of rim, with the pads mounted in center of adjustment.
Take a look at new project with wheels mounted. Scribe top of rim on the frame on both sides. Scribe another line 15mm -that's center line of mounting bolt.
Made a quick little fixture to hold things square, do this on the donor before cutting loose.
