MazdaFlyer
Like “RadioFlyer”
Did a little experimenting with the steering knuckles today. I’m using a 2x4 cross member to experiment with wheel track. The knuckles have some positive camber. Toe will be adjustable.
I mounted the brackets with 5/16” Grade 8 bolts. The wood beam will allow me find an acceptable track width as it can be shortened easily. I used 3/8 Heim connectors for tie rod ends and cut and threaded 3/8 rod with 3/8-24 NF ends.
This steering stuff is in “freestyle” mode now. I need to think though connecting it to frame and framework. I have a thought on the steering connection. When I get the front end worked out width wise I’ll use a couple of angles to replace the 2x. Trial and Error at best.
The wheel track with the 2x should be about 8” wider than the current 24” axle setup.
