Just a question, did it ever run through your mind to ditch the two front wheels idea, and just put one under the sheet metal, so it was more like a motorcycle fairing?
Maybe blind ambition, but thanks for watching. My background as an educator, architectural designer and specifier were all creativity related vocations. It’s in my blood, this forum and these builds are my creative outlet at present.this looks like a fun build. I hope you are having fun and learning a lot. You have great ambition!
Rainy again today do the axle change out may be on hold for today. Some big lights might work well, I have a couple of small ones that I’d thought about yesterday. Again this is all about trial (trowel) and error.Just seeing your support bolts for the hood coming out the side made me think; what if you made those even longer and mounted twin head lamps off them, one to each side?
I really believe your steering answer is a wider front axle. Your turning radius will be greatly improved, and the stability hugely enhanced. Plus, if you go with the big headlights on the sides, they will fill in part of the 'gap' the wider axle will create.
Well it’s still a work in progress...3.5 months left. Here is the articulated idea.@MazdaFlyer I think you made the right choice. It needs trike for support, can't imagine how top-heavy it is, seems unmanageable on two wheels. Oj's suggestion on headlamps sounds slick, the hive mind is really working on this one
Here’s another scenario with the hood sectioned to reduce the width and placed over the frame and sorta making a rear fender. The manual photo mock-up isn’t to scale though. But I think it transmit the general idea.Just a question, did it ever run through your mind to ditch the two front wheels idea, and just put one under the sheet metal, so it was more like a motorcycle fairing?
The above photo is what I was trying to describe in my last quote. Actually rather liked this concept. Steering solved.@MazdaFlyer I think you made the right choice. It needs trike for support, can't imagine how top-heavy it is, seems unmanageable on two wheels. Oj's suggestion on headlamps sounds slick, the hive mind is really working on this one
It would have that 'tractor in front / bicycle in back' kind of look. You decide which one's the 'party'.
Yes with the time invested so far it’s do or die with the two wheels up front. I have a couple of gas filled struts on the way. I may hold off on the axle experiment until I can try the struts. I think eventually though I’ll move wheels out some for a bit more clearance.Some of those concepts are pretty cool like the articulated one. However I think the hood really needs the trike. You're on the right path, don't sway now. It's just some engineering
I would try a wider axle. Since you've got threaded rod, you could go out to max width and bring the wheels in incrementally until you find a sweet spot between show and go. Not as simple, but I believe some caster and camber (just a touch) could help some of the handling issues
I’m in agreement with you on the look but I feel I need a bit more clearance to ride safely. Waiting on some gas struts to replace the or supplement the springs. After that trial I’ll probably experiment with the wheel track.I agree, the path you are currently on is the correct path. I like the compact front end you have now. While making it wider may help with control, style wise it would take away tremendously from the sleekness of the hood if the wheels were farther apart. The current proportions are much more artfully appealing.
Currently the front wheels flow and are part of the bike, if you put them out farther, they become distracting outriggers.
I’m in agreement with all three of you, thus the dilemma. The goal is to get it rideable according to the rules. I’d also like for it to have good aesthetics also. Shows are scarce these days and so is go...so driveway, up and down the block.It's the old 'show' or 'go' battle once again. If as a bicycle it's intended to be safely and somewhat comfortably ridden, at least by it's builder anyway, that has to be considered. If it's just an art piece for 'show' then the aesthetics prevail over the physics. Finding the compromise is the real trick.
I do like the two wheels in front the best. And Captain's idea of starting wide and gradually getting down to the optimal ride / look position is a good one. It would have that 'tractor in front / bicycle in back' kind of look. You decide which one's the 'party'.
Uh oh, he's breaking out the steering knuckles!
