BO15 WAHA-SEDB-3 (TRIKE-TOR...2nd Place)
Add a little brown and caramel color to your stain and some very strong smell, and it could pass for a creosote covered beam. Boy, that stuff is nasty. We covered hundreds of feet of board walk with it back in the '80s to protect it from the bogs below and the wet forest and damp air off the south shore of Gitchie-gumee. I'm sure I have some brain damage from those days.
Are you sure you don't want to rat-ina the hardware some? Mix up a little home brewed rust mix, and go for it!
Keeping some shine, you should talk...all that glitz from the patina master. Anyway they all need some bling.
I mounted up the warning triangle. 91 muggy degrees today at present.
The I roughed out a front bumper with an old broom stick and 1/8”x1-1/4” flat bar.
Really nice work on that bumper and the triangle fits perfectly! Now, tackle the seat / saddle and bring 'er home!
EDIT: Oops! I forgot, you did get your saddle deal worked out. Settled on the bars / steering wheel debate yet?
After mounting the warning triangle and mocking up the bumper I took some shots to experiment with overall visual effects.
Still need to add finish to chainguard, recut one tie rod, find wider rear tire (have 3.0” wide space), finish up steering control, add front light(s?) and effects, fix final hood mount rod and maybe other stuff.
Lots of time...getting hot here so morning work in order.
Great reflector. Love that bumper!
Thanks! I was thinking bigger but this one fits the scale.
Bumper and triangle are just the right amount of seasoning!!!!!
Thanks! Got lucky with the scale this time.
[emoji106][emoji106][emoji106][emoji106][emoji106]
Thanks! I think the current seat stays. The steering situation hasn’t gelled completely yet.
Very nice.
Sent from my SM-G986U using Tapatalk
Thanks!
That fenders really pulls it all together well.
Love the front bumper.
This is such a killer build!
Thanks!
The fender makes the tire look small. I’ve got 3” clearance at the lower chain stays. Have a 2.5” tire in mind to fit the rear.
The bumper is about the simplest thing in the whole build...KISS principle at work.
There’s been numerous comments about tractor style tread or aggressive knobby style tires. The 20’s I had ordered for the front ended up being out of stock so we agreed on the substituted Husky smoother tread tread.
Now I’m thinking to reduce rolling resistance I’ll try a smoother tread 2.50” wide tire on back. The fender will basically hide the tread anyway.
I’ve used these Sunlite Sandy Beach tires on other builds. They measure out at around 2.35” inflated.
There’s also a Sunlite Revolution tire available spec’d at 2.50” which come in at almost 2.50”.
Both are all black with no graphics or color. And this Trike-Tor is a hybrid after all.
The David Bradley walk behinds used various style tires.
Borrowed photo from web.
My David Bradley hybrid.
Man that neon lime green is wild! Gonna paint the wheels and chain guard on the Trike-Tor the same color? :)
