█★█ starsNbars █★█ 38 Hawthorne Twin Bar 5 Bar ☠ - Red White and RUST - Tied for 7th Place
Worked on the light tonight. First I removed the bracket and hammered out a little flatter then reattached it to the center of the light.
View attachment 4309 View attachment 4310
The I put on some gloves and googles and used my Dremel to cut the backside of the sealed headlight glass. I should have worn long sleeves too.
View attachment 4312 View attachment 4313 View attachment 4315
But it cleaned up nicely.
View attachment 4316 View attachment 4317 View attachment 4318 View attachment 4319 View attachment 4320 View attachment 4321 View attachment 4322
Man, that light turned out very nice. Did you cut the back of the headlight housing or the glass?
Thanks for the step by step. That was pretty cool to see the transformation. Nice work man!
Wow, that's pretty hard core cutting a sealed beam bulb apart to make a lens!:41::thumbsup:
I am pretty sure that a lot of other RRBers have done similar grinding on sealed beams. Don't know if I have seen anyone do it for just the lens, but I know plenty have cut holes in the back to LEDize them. Just remember that you are grinding glass and protect yourself and also make sure you clean up good, so that you don't rub a particle into your eyes.
Taped up the lense, cut out the surround of a star, and painted the surround with the Hammered Black.
Manipulated some old chainguard braces to finally mount my Iver Johnson chainguard. I think I did a pretty good job of centering the chainring. The dropstand tab forced me to let the back end curve out some.
Used some hanger strip that I got at a yard sale just last weekend to make a clamp for the tank.
Mounted the massive prewar kickstand and 1943 leather Cleveland tag and jewel that I picked up from @marius.suiram . This thing is HUGE but it tucks away pretty well. @Double Nickle thought it might even be motorcycle related.
BUILD OFF 6 FLASHBACK
Found this pick from my first build (and Build Off) BEER RUN when I was considering this tank. This was the EARRRRRRRRLY stage of BEER RUN. I don't think I even had a name for it at this point.
View attachment 4376 View attachment 4377 View attachment 4380
View attachment 4378 View attachment 4379
View attachment 4381 View attachment 4382 View attachment 4383 View attachment 4384 View attachment 4385 View attachment 4386
KF,
That kickstand is killer.
Love the work on the headlight.
Cutting sealed beam headlights is a pain but if you use diamond tip were covered bits; keep cool water running over the glass and go slow it can be done without a big mess or cracked glass.
BTW the hammered black is one of my favorite rattle cans.
Looks great.
Looks great.
I used a Dremel diamond cutoff wheel to do the cutting. I just kept going in slow circles around the perimeter.
The diamond cutting wheels are a pain to use.
If you cut glass again use a sink or have somebody help and keep cool water on it; it helps keep the debris down and prevents cracking from heat.
