Thank you for that tip, I will search for that in our local paint shop.For that style of intricate pattern, I'd suggest that frisket paper is superior to common masking tape. Find it in art supply stores. It's likely to eliminate any pesky bleed-through and deliver crisp edges.
BRIKbikes, Beixo, and Biomega are brands that work with a shaft.a shaft drive bicycle is on my bucket list.
There are several cheap mountainbikes for sale second hand with these shaft drives:
Nexus 3 hub.
These could be very cool klunkers!
My 'BRIK' front sprocket came in and at first glance I thought they are not compatible.
But when I pushed them together and found the right angle (like a chainstay that goes outwards to the rear) it fits perfectly!
Now I gotta find the standard for the splines so I can machine a shaft. After designing the whole BB offcourse.
19mm outside diameter of the splines.
About 17.3mm inside diameter of splines.
25mm bearing.
Number of teeth.
Excuse me if this is a little offtopic, but its just so cool and not a full on project just yet to make a new topic about it.
