Same result. So…Maybe it's a problem with the fork instead of the wheel. Try mounting the wheel backward to see what you get.
I got a cheapo snap ring pliers set that works good for stuff like this. Similar to these:Any tips?
These methods work in a pinch (it's all I had for years) but snap ring pliers make life so much easier.Yep, it is a snap ring, so you either need a pair of snap ring pliers, the right kind of long nosed pliers that will fit, or a couple of small screwdrivers and a tub of luck![]()
https://www.ebay.com/itm/3947277604...nEChXKSKup9f0OAdmNoehEZ81yk=|tkp:BFBMusaxudJi
Amazon and Harbor Freight probably have stuff like this too.
And don't forget
Those snap rings go flying!
I'll measure mine tomorrow. You might be stuck prying it out with a small screwdriver (I have some tiny screwdrivers meant for working on eye glasses) or awl. That works though. If you have 2 small prying devices use one to lift the end and put the other under the exposed part as a lever then work your way around. Sometimes it's a real PITA, sometimes it pops right out, but it can get the job done. It can be done with 1 small screwdriver but can be tedious and challenging. If it gets real tough I can drive down to watch you suffer while sipping an iced mocha-ccino (or something equally insipid). That usually helps.Do they make snap ring piers for a snap ring so small? It's only like 5mm in diameter.
Yes, I have two jeweler flatheads, but I wasn't successful. It keeps spinning around. Like you said, a real PITA.I'll measure mine tomorrow. You might be stuck prying it out with a small screwdriver (I have some tiny screwdrivers meant for working on eye glasses) or awl. That works though. If you have 2 small prying devices use one to lift the end and put the other under the exposed part as a lever then work your way around. Sometimes it's a real PITA, sometimes it pops right out, but it can get the job done. It can be done with 1 small screwdriver but can be tedious and challenging. If it gets real tough I can drive down to watch you suffer while sipping an iced mocha-ccino (or something equally insipid). That usually helps.
That was essentially my idea, but I envisioned it uncoiling and cutting me to shreds, or some other disaster. But maybe I'll push forward with that.I'm not sure what tools you have available, but could you try coiling the tape measure into a tight bundle, then holding that against a belt sander or other abrasive surface? Perhaps secure the bundle with a zip tie so it doesn't unwind during the process.
THERE'S a surface you can work with!
If only I had a fab shop to talk to. We could be such good friends....So I talked to my fab shop about modifying an existing bolt.
If only I had a fab shop to talk to. We could be such good friends.![]()
