Thanks yoothgeye!!
The material that I used for the tanoue cover, sidecar seat and grips is indeed pleather that
I picked up at a local fabric store for $6.00!! The wood that I carved was mdf and after cleaning all of the carved areas with and old toothbrush I used a torch to get all of the fine fibers smoothed down. (no way to really sand inside the letters and boarder) I folded the material on the tanoue cover so that I could add the stitching around the outside so it is actually two layers of material.
No Expert Here! but I think that there are two major key’s to making this happen..... First, I opened the flap on the inside and sprayed just enough 3m adhesive to ooze into the letters during the crimping possess, second is that when I placed everything in the vice I used a piece of wood on the opposite side with a leftover piece of carpet so that the fluffiness of the carpet would help to push the material into the mold. Don’t forget you need to crank that vise down and walk away for at least a day so it will set up. It worked for me plus the 24 hour wait to see if it turned out it’s fun stuff!! Try it out on some scrap pieces and let me know how it comes out! Hope that helps you!!
If anyone else out there has something to add please throw in your two cents. This was a first time try for me and I would hate to send someone in the wrong direction!
Later, HL
