While the blue does compliment what you've got going so far, I really like your clean and mean idea with the black and chrome. It's really going to be smooth! There is such a great flow to this bike.
That settles that.The blue wheels are definitely just loaners and the tape is there to prevent me from jacking up the paint/powdercoating. I’ve been wanting to strip and polish my wheels since the day I bought them. Once I ‘do’ the tank and guard, hopefully the ‘grand plan’ will make sense.
Going classy on this one, no ‘natty, ratty’. Now, next year…I’ll require a tetanus shot![]()
I have kicked around another ‘color’ for any graphics.Deal,
I know where you're coming from. Consider a secondary color. A hint of color can make all the difference.
Didn’t mean to sound abrupt bud.
Glad you brought up the reflective nature of chrome. During a sunny day the bike will take on a bluish hue. Shiny components, bare metal even paint reflect the surrounding environment. One reason I often use chrome plated rims.I have kicked around another ‘color’ for any graphics.
I hear ya on a possible accent color, I’ve kicked around the idea of something for any graphics I may do. I was gonna keep this part as a ‘secret’ until I was ready to mock it up, but I picked this up as a possible tail light. The red/green will be a reference to the port/starboard of the marine heritage of Savannah.
I was thinking to install the lens ‘sideways’ with the red side down (tail light) reflecting against a chrome fender and green side up providing some ‘cool’ color at night. Here is a 5 second mock-up of it sitting on my original fender choice.
Agreed. Black and chrome with that beautiful frame and slick parts=pure coolWhile the blue does compliment what you've got going so far, I really like your clean and mean idea with the black and chrome. It's really going to be smooth! There is such a great flow to this bike.
You guys are opening up so many lighting options for the RRB world. Really nice work Doc. Thank for sharing.Worked on sanding the wheels a bit last week, nothing really worth showing yet. BUT, I did mess around with the headlight.
The bulb in it was a 55 watt unit.
However, I could barely get it to glow with a 9v battery. So, I picked up a 20 pack of these 2mm LEDS (wired with a resistor already)
View attachment 201973 View attachment 201972
I started with a little Dremel surgery to separate the existing bulb from its mounting plate
Six of the new LEDs fit perfectly in the plate
On the first version, I installed the them straight in, mostly to test my solution. Twisted all the red leads together and all the black leads together and wired them to a 9v battery pack. View attachment 201976 View attachment 201977
Even with a little ambient light coming through the door in the room, I think this will be plenty bright to be seen
But this ‘clumsy’ version was too tall to fit inside the back enclosure
So, I bent each one of the LEDs 90 degrees, so the wires would lay flat against unit
This is a MUCH cleaner method
I tested each bulb individually to make sure they weren’t damaged by the bending and finished taping everything up.
That’s as far as I’m gonna go with it right now. I need to go buy some larger gauge wire to connect to the grouped leads and from there to a switch and the close the loop with the battery pack, but that’s for another day. Put the light back together and shelved it.
Back to sanding the wheels tomorrow, gonna get rough spoke length measurements from the borrowed blue set and make ANOTHER attempt at lacing
Stay tuned!
Nice work! I’m all thumbs when it comes to electricalWorked on sanding the wheels a bit last week, nothing really worth showing yet. BUT, I did mess around with the headlight.
Stay tuned!
Got them both through the 400 grit phase and one through 800. I think I found donor wheels with the right length spokes, we’ll in about 2 more rounds of sanding and polishing compound. I finished wiring the headlight today, purchased a few parts for the horn and lighting electrical.
For the first time in entering these Build Offs, I’m concerned about finishing on time with bike the way I want to present it. But, I’m gonna try to cross that line!
Bling! Bling!
Register today and take advantage of membership benefits.
