Same here when I use my phone.Has anyone else been having any problems with photo bucket? I been having problems getting my pics right side up I use to just rotate the pic then copy and paste but now it don't want to rotate. This has just happened the last couple times I tried usually it works fine.
There is two tubes valve stems 180 from each other I have smoothed the welds hopefully the tubes will be okay I've seen a few other people on here do th same thing without any problemsLooks good Jamie825
I have question about the rims you joined.
1/ Do you have a inner tube inside? and if so doesn't the rims cut into the tubes or are they taped?
thank you I will give that a try next time.You're using the wrong link. Use the direct link provided. On your "All Images" page there will be a drop down on each pic. I think it's the second one down? It's the "Direct Link". It will post it at whatever size you made it.
I guess for cruising without potholes should be ok... I have so many of these thin rims,thought to give it a go,seen a couple of ways to do it,this seems the easiest...There is two tubes valve stems 180 from each other I have smoothed the welds hopefully the tubes will be okay I've seen a few other people on here do th same thing without any problems
I probably don't do near as much riding as some on here but I will post about it if I do have any trouble out of them and yeah cruising is the only riding I will be doing.I guess for cruising without potholes should be ok... I have so many of these thin rims,thought to give it a go,seen a couple of ways to do it,this seems the easiest...
I tried the one that says direct link and only the link came up its in the post I made before this I was using the forum link before when pics come up small. Thanks in advance for any helpthank you I will give that a try next time.
