So last time I built up my roadmaster with a motor it went okay, but the chinese 80cc tin motor wasn't very satisfying, so I'm moving on to bigger and better things.
I've had this old snowblower thumper of a two stroke laying around for a long time, I was planning on running it on a vintage mini bike, but never found a suitable gas tank for that project. Yesterday I tried fitting it in the frame, and with the exception of being a little wide, I know I can make it work. Since it's wide I'm going to try and use the clutch/jackshaft system off an old Whizzer (if I can find one, I'm looking, got one?) which would both work as my clutch and I'd be able to run another belt off of it toward the rear wheel, or I might have to borrow a friends lathe and use what I learned in school and make one myself. I've also been throwing around the idea of using a centrifugal mini bike clutch on it somewhere, but it's all in my head now. If that didn't make sense, just wait and it will once I get building.
But to start this build out, here's the engine as it sits now. That's the carb in the plastic bag, it's a chainsaw style carb without a float so I can rotate it anyway I want to get it to fit in the frame.
And I can't wait to get started!
