Red Rider
Going all in on “Red.”
I regretted selling that all red Columbia middle weight a few years back…. Trying to relive past builds:
So……. What a pain!!!
This has actually held me up for a couple of weeks!!!!
I robbed this bike of a shift lever screw in an emergency to finish the varsity party bike when I found the shift lever screw on the downtube was stripped.
-I did not realize the size and thread pitch on these screws would be so tough to get!!!!
After a lot of online searching, I finally got the time to head to a local bike shop (Mello Velo) and they had to search but found the right screw. Theirs was slight Shorter and it’s a Phillips head…. But it works fine! They were super nice and comp’d me the screw!!!!!
Factory
Mello Velo comp’d part
And….. I’ve got a mechanical issue here with the drop-bar brake levers jammed on straight bars
I guess I can tune my brakes so I need little distance to engage or I suppose I could scoot them out to the end of the bar.
May look sort of goofy, could look cool; or different anyway.
(it appears I also have a hover board and a teddy bear too!)
And, as much as I hate to do this on a glorious fall day here in upstate, with daylight savings this weekend, after work wrenching just won’t be possible.
Set up my stand in the basement
Lol you are a better builder than me. I chose to ride instead, which means that I won't be painting
Ha-Ha! I‘m not sure about that!
I would have ridden! I’m coming down the home stretch of a sinus infection. Doc says too much sucking in fall air with mold and pollens.
I chose to lay low on my riding until I’m 100% healthy / off of antibiotics .
There is a tool that fits the teeth on the inside the freewheel, No chain whip needed though. I don't know how to remove them without using the correct tool however.
Thanks! Thought so! I was hoping someone had a trick that would keep me from spending $10 on the lock-nut thing!
So, after some thought and some research, I’ve decided to forego the original wheels on this thing and replace them with the wheels off my trash pick Kabuki bike.
After further review, that bike is really nice!!!!
They did need a good scrub, but they are more true and in much better shape than the wheels that came on the bike.
They also have the dork disc and the tubes were a better fit.
Finally, most importantly about the swap: cost: $0.00.
Ready to roll!!!!
