You reckon?I'm not the only crazy one here.
Don't mean to belabor this but here's bike I had in mind. I had saved the image but I don't remember who the builder was.
I thought it was a cool idea.
this looks fun and effective..
That bike was made by @Glen in New Zealand for an earlier Muscle Bike Build-Off, great job and a quick little bike by the looks of his videos.Rad set-up; bike looks awesome
From memory he spread the forks to fit a standard hub.I agree. I wonder where they got a 100mm OLD coaster hub.
Keep your finger pointy at the others... i refuse acknowledge anything here but a rational discussion...
Hey 808 why wouldnt the concept you had reguard the dual sprokets u mentioned when i almost bought that terrible tandum for the hub... could only one be a freewheel and the inner the stock coaster sprocket? Youd loose the foot coaster but i guess youd be able hook up like that front has
Not really difficuly to solve the chain routing.. juat go north up the seat stay.. there is always room in the stay man.Well, HOLY CRAP!-- ladies and gentlemen.... @pholTmonx solved this little puzzle for us, aside from the cable routing to pull the inner sprocket the proper way in order to engage the brake....Wow! Totally possible; you just need a coaster hub with an English-threaded driver (easist to find is Velosteel)....a big threaded track cog, some spacers, a NDS loose-ball brit-threaded BB cup, a freewheel, and you'd have to spread the dropouts a bit, as this would likely be wider than the typical CB hub. I need to mock this up so folks can see what we're talking about.... Hardest part would be running the brake-chain to a cable where it would pull the inner chain back to engage the brake.
Pffffftttt to the ney sayers and logic blocked.
Well with what 808 is talking about we still havent mastered the arm.. but figured out how could achive a hand powered coaster for the rear..The only reason I asked about using the brake arm is because when you apply the brakes on a coaster hub there's movement at the arm.
I just assumed it could be used.
But this idea seems like it might actually work.
Well, I'm pretty sure I have a bendix hub.Update: this won't work on a Velosteel, not without modifications that probably aren't feasible. The threaded driver on the Velosteel hub takes a lockring, and that stepped-down reverse-threaded part of the driver where the lockring would go is too wide to allow use of the NDS BB cup. You could probably mill down that section of the driver, and bore out the BB cup a little bit, and maybe it'd work, but there ain't much metal to work with on either part.
FWIW, it'd still be easy to do on a "normal" freewheel hub, in terms of running the dual freewheels (I've assembled that, back when i wanted to build a retro-direct bike)...and i still think that Falstaff's dream of a rear hand-actuated coaster could work, but you'd need one of these:
(and a Bendix hub...)
I'm tempted to give a velosteel driver to my machinist buddy and tell him to "make it work;" i'll at least have him look at it and let me know if he thinks it'd be feasible.
So I take it this replaces the cog and allows you to put a freewheel on. How would you then brake?Yeah, me too.... those threaded driver conversions are hard to come by, though....
