Re: Cobrafreak's board track racer project, never ends!
the gx engine is used in cart racing right? that's going to be great.
From what I hear, yes. Pretty much the same, other than displacement. I read a speed trick for the GX160 which is to use GX200 head gaskets as they are thinner and it will raise the compression ratio nicely for more power. How much is cheap? Brand new GX200 clones are at Harbor Freight for around $79 with coupon. For $20 more you can get a two year warranty, no questions asked. Blow it up, get a new engine.harry76 said:I will be watching this. I may build much the same in the future, im probably buying a fairly cheap Honda GX160 next week, just gotta go look at it. Are they much the same engines?
harry76 said:Thats looking good Cobra, real good. And while i was a fan of what you did with your chinagirl, this motor in your frame is a huge improvement. What flywheel do they have? Do they have cooling fins that you need to remove? Are you going planning not to run a heat shield (or shroud), because i read in Lurkers thread how he had heating problems, are you just going to see what happens? Look forward to seeing your progress....
stocksucks said:Real good lookin engine.
Can we hear it?
harry76 said:You said you would use a CVT didnt you? If so where do you find these and how much are they worth? Sounds like a good idea....
Any other ideas on how you will make the engine vintage looking or are you going to do it as you go? And keep the pics comin....
stocksucks said:Why didnt you use the stock one?
