Re: Cobrafreak's board track racer project, never ends!
About 33mph. It did not lock the rear wheel. No damage other than the broken spokes and the original disk brake adapter when I removed it from the wheel. I took an added measure to insure that this type of thing would not happen again. I went to a motorcycle accessory shop and got a chain slack adjuster wheel made for a dirt bike. Rather than using a skate board wheel as my slack adjuster wheel, the motorcycle slack adjuster is tougher with better bearings, stronger urethane, and most importantly, a chain channel that is of a really good design that will not let the chain fall off. My chain alignment is perfect now. I set it with a laser. I'm good to go now. Lesson learned. If your chain is one degree off and you think it will be fine, it won't be. Do whatever it takes to make it absolutely perfect.
harry76 said:Sorry to hear that Cobra, but thanks for the headsup.... Glad to see you are back on the road.
How fast were you going when the chain jumped off? Did it lock the rear wheel? Did it damage your faux drum cover?
